Time Before: 0.02332 seconds
Time After: 0.03299 seconds
Time Taken: 0.00967 seconds
Time Before: 0.03310 seconds
Time After: 0.03346 seconds
Time Before: 0.03368 seconds
Time After: 0.03382 seconds
Time Before: 0.03466 seconds
Time After: 0.03757 seconds
Time Taken: 0.00291 seconds
Time Before: 0.03390 seconds
Time After: 0.04222 seconds
Time Taken: 0.00832 seconds
Time Before: 0.05270 seconds
Time After: 0.05312 seconds
Time Before: 0.05565 seconds
Time After: 0.05695 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05203 seconds
Time After: 0.05718 seconds
Time Taken: 0.00515 seconds
Memory After: 2,261.703 KB
Time Before: 0.08732 seconds
Time After: 0.08747 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10816 seconds
Time After: 0.10946 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11865 seconds
Time After: 0.11881 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12189 seconds
Time After: 0.12333 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121190', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.14407 seconds
Time After: 0.14440 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
