Time Before: 0.00158 seconds
Time After: 0.00222 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00229 seconds
Time After: 0.00281 seconds
Time Before: 0.00309 seconds
Time After: 0.00328 seconds
Time Before: 0.00427 seconds
Time After: 0.00730 seconds
Time Taken: 0.00303 seconds
Time Before: 0.00336 seconds
Time After: 0.01169 seconds
Time Taken: 0.00834 seconds
Time Before: 0.01402 seconds
Time After: 0.01451 seconds
Time Before: 0.01836 seconds
Time After: 0.01961 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01331 seconds
Time After: 0.01987 seconds
Time Taken: 0.00655 seconds
Memory After: 2,261.703 KB
Time Before: 0.02588 seconds
Time After: 0.02602 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02857 seconds
Time After: 0.03107 seconds
Time Taken: 0.00249 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.033972024917603
Time Before: 0.03572 seconds
Time After: 0.03594 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03811 seconds
Time After: 0.03957 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=121232'
Time Before: 0.05380 seconds
Time After: 0.10264 seconds
Time Taken: 0.04884 seconds
Memory Before: 4,288.000 KB
Memory After: 4,288.242 KB
Page generated in 0.052901983261108 seconds with 9 queries, spending 0.058637142181396 doing MySQL queries and -0.0057351589202881 doing PHP things.
