Time Before: 0.00177 seconds
Time After: 0.00229 seconds
Time Before: 0.00236 seconds
Time After: 0.00304 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00337 seconds
Time After: 0.00356 seconds
Time Before: 0.00434 seconds
Time After: 0.00707 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00363 seconds
Time After: 0.01043 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01244 seconds
Time After: 0.01289 seconds
Time Before: 0.01536 seconds
Time After: 0.01664 seconds
Time Before: 0.01175 seconds
Time After: 0.01682 seconds
Time Taken: 0.00507 seconds
Time Before: 0.02424 seconds
Time After: 0.02442 seconds
Time Before: 0.02662 seconds
Time After: 0.02786 seconds
Time Before: 0.03094 seconds
Time After: 0.03108 seconds
Time Before: 0.03317 seconds
Time After: 0.03463 seconds
UPDATE session SET lastactivity = 1776608124, location = '/forums/private.php?do=newpm&explain=1&u=121249' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04686 seconds
Time After: 0.04714 seconds
