Time Before: 0.00137 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00244 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00275 seconds
Time After: 0.00289 seconds
Time Before: 0.00362 seconds
Time After: 0.00601 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00294 seconds
Time After: 0.00934 seconds
Time Taken: 0.00641 seconds
Time Before: 0.01158 seconds
Time After: 0.01200 seconds
Time Before: 0.01344 seconds
Time After: 0.01742 seconds
Time Taken: 0.00398 seconds
Time Before: 0.01086 seconds
Time After: 0.01759 seconds
Time Taken: 0.00673 seconds
Time Before: 0.02263 seconds
Time After: 0.02278 seconds
Time Before: 0.02525 seconds
Time After: 0.02696 seconds
Time Taken: 0.00171 seconds
End call of global.php: 0.029290199279785
Time Before: 0.03061 seconds
Time After: 0.03082 seconds
Time Before: 0.03284 seconds
Time After: 0.03437 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=121275', badlocation = 1
Time Before: 0.04665 seconds
Time After: 0.04694 seconds
Page generated in 0.045747995376587 seconds with 9 queries, spending 0.011331558227539 doing MySQL queries and 0.034416437149048 doing PHP things.
