Time Before: 0.00142 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00253 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00284 seconds
Time After: 0.00299 seconds
Time Before: 0.00360 seconds
Time After: 0.00616 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00306 seconds
Time After: 0.00960 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01164 seconds
Time After: 0.01185 seconds
Time Before: 0.01362 seconds
Time After: 0.01482 seconds
Time Before: 0.01101 seconds
Time After: 0.01500 seconds
Time Taken: 0.00399 seconds
Time Before: 0.02003 seconds
Time After: 0.02021 seconds
Time Before: 0.02225 seconds
Time After: 0.02351 seconds
End call of global.php: 0.025135040283203
Time Before: 0.02656 seconds
Time After: 0.02672 seconds
Time Before: 0.02863 seconds
Time After: 0.03004 seconds
SET lastactivity = 1776534894, location = '/forums/private.php?do=newpm&explain=1&u=121309', badlocation = 1
Time Before: 0.04269 seconds
Time After: 0.04304 seconds
Page generated in 0.041774988174438 seconds with 9 queries, spending 0.0080742835998535 doing MySQL queries and 0.033700704574585 doing PHP things.
