Time Before: 0.00169 seconds
Time After: 0.00235 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00245 seconds
Time After: 0.00297 seconds
Time Before: 0.00321 seconds
Time After: 0.00334 seconds
Time Before: 0.00421 seconds
Time After: 0.00684 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00341 seconds
Time After: 0.01144 seconds
Time Taken: 0.00803 seconds
Time Before: 0.01345 seconds
Time After: 0.01369 seconds
Time Before: 0.01518 seconds
Time After: 0.01638 seconds
Time Before: 0.01268 seconds
Time After: 0.01655 seconds
Time Taken: 0.00387 seconds
Time Before: 0.02228 seconds
Time After: 0.02246 seconds
Time Before: 0.46630 seconds
Time After: 0.46821 seconds
Time Taken: 0.00191 seconds
Time Before: 0.47466 seconds
Time After: 0.47484 seconds
Time Before: 0.47752 seconds
Time After: 0.47906 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1773271970, location = '/forums/private.php?do=newpm&explain=1&u=121359' WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.49586 seconds
Time After: 0.49620 seconds
