Time Before: 0.01704 seconds
Time After: 0.02116 seconds
Time Taken: 0.00412 seconds
Time Before: 0.02127 seconds
Time After: 0.02174 seconds
Time Before: 0.02204 seconds
Time After: 0.02221 seconds
Time Before: 0.02304 seconds
Time After: 0.02633 seconds
Time Taken: 0.00329 seconds
Time Before: 0.02228 seconds
Time After: 0.03045 seconds
Time Taken: 0.00817 seconds
Time Before: 0.03823 seconds
Time After: 0.03844 seconds
Time Before: 0.04108 seconds
Time After: 0.04236 seconds
Time Before: 0.03742 seconds
Time After: 0.04261 seconds
Time Taken: 0.00519 seconds
Time Before: 0.07529 seconds
Time After: 0.07550 seconds
Time Before: 0.08705 seconds
Time After: 0.08835 seconds
Time Before: 0.09760 seconds
Time After: 0.09778 seconds
Time Before: 0.10072 seconds
Time After: 0.10226 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121388', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.12103 seconds
Time After: 0.12129 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
