Time Before: 0.00178 seconds
Time After: 0.00234 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00245 seconds
Time After: 0.00288 seconds
Time Before: 0.00312 seconds
Time After: 0.00325 seconds
Time Before: 0.00420 seconds
Time After: 0.00698 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00332 seconds
Time After: 0.01253 seconds
Time Taken: 0.00920 seconds
Time Before: 0.01449 seconds
Time After: 0.01470 seconds
Time Before: 0.01785 seconds
Time After: 0.01914 seconds
Time Before: 0.01370 seconds
Time After: 0.01943 seconds
Time Taken: 0.00573 seconds
Time Before: 0.02748 seconds
Time After: 0.02761 seconds
Time Before: 0.02990 seconds
Time After: 0.03119 seconds
End call of global.php: 0.03390097618103
Time Before: 0.03530 seconds
Time After: 0.03549 seconds
Time Before: 0.03779 seconds
Time After: 0.03922 seconds
SET lastactivity = 1782961426, location = '/forums/private.php?do=newpm&explain=1&u=12140'
Time Before: 0.05157 seconds
Time After: 0.05186 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.050678014755249 seconds with 9 queries, spending 0.0081853866577148 doing MySQL queries and 0.042492628097534 doing PHP things.
