Time Before: 0.00147 seconds
Time After: 0.00196 seconds
Time Before: 0.00202 seconds
Time After: 0.00251 seconds
Time Before: 0.00279 seconds
Time After: 0.00298 seconds
Time Before: 0.00385 seconds
Time After: 0.00674 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00305 seconds
Time After: 0.01164 seconds
Time Taken: 0.00858 seconds
Time Before: 0.01382 seconds
Time After: 0.01419 seconds
Time Before: 0.01671 seconds
Time After: 0.01805 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01316 seconds
Time After: 0.01826 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02406 seconds
Time After: 0.02422 seconds
Time Before: 0.02646 seconds
Time After: 0.02769 seconds
End call of global.php: 0.029873132705688
Time Before: 0.03126 seconds
Time After: 0.03144 seconds
Time Before: 0.03376 seconds
Time After: 0.03523 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=121444'
Time Before: 0.05034 seconds
Time After: 0.05064 seconds
Page generated in 0.049409151077271 seconds with 9 queries, spending 0.008622407913208 doing MySQL queries and 0.040786743164062 doing PHP things.
