Time Before: 0.03127 seconds
Time After: 0.03928 seconds
Time Taken: 0.00801 seconds
Time Before: 0.03940 seconds
Time After: 0.03980 seconds
Time Before: 0.04004 seconds
Time After: 0.04021 seconds
Time Before: 0.04106 seconds
Time After: 0.04322 seconds
Time Taken: 0.00216 seconds
Time Before: 0.04036 seconds
Time After: 0.04744 seconds
Time Taken: 0.00708 seconds
Time Before: 0.05465 seconds
Time After: 0.05503 seconds
Time Before: 0.05655 seconds
Time After: 0.05778 seconds
Time Before: 0.05398 seconds
Time After: 0.05803 seconds
Time Taken: 0.00405 seconds
Time Before: 0.10989 seconds
Time After: 0.11004 seconds
Time Before: 0.13109 seconds
Time After: 0.13232 seconds
End call of global.php: 0.13453006744385
Time Before: 0.14329 seconds
Time After: 0.14347 seconds
Time Before: 0.14608 seconds
Time After: 0.14753 seconds
SET lastactivity = 1776801280, location = '/forums/private.php?do=newpm&explain=1&u=121458', badlocation = 1
Time Before: 0.16446 seconds
Time After: 0.16473 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.16343593597412 seconds with 9 queries, spending 0.0076241493225098 doing MySQL queries and 0.15581178665161 doing PHP things.
