Time Before: 0.01986 seconds
Time After: 0.02521 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02531 seconds
Time After: 0.02581 seconds
Time Before: 0.02612 seconds
Time After: 0.02625 seconds
Time Before: 0.02693 seconds
Time After: 0.02955 seconds
Time Taken: 0.00263 seconds
Time Before: 0.02631 seconds
Time After: 0.03368 seconds
Time Taken: 0.00738 seconds
Time Before: 0.04303 seconds
Time After: 0.04339 seconds
Time Before: 0.04577 seconds
Time After: 0.04703 seconds
Time Before: 0.04210 seconds
Time After: 0.04728 seconds
Time Taken: 0.00518 seconds
Time Before: 0.08291 seconds
Time After: 0.08306 seconds
Time Before: 0.10266 seconds
Time After: 0.10392 seconds
Time Before: 0.11647 seconds
Time After: 0.11665 seconds
Time Before: 0.12008 seconds
Time After: 0.12165 seconds
Time Taken: 0.00157 seconds
UPDATE session SET lastactivity = 1776710572, location = '/forums/private.php?do=newpm&explain=1&u=121474' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.13966 seconds
Time After: 0.13994 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
