Time Before: 0.02327 seconds
Time After: 0.03069 seconds
Time Taken: 0.00742 seconds
Time Before: 0.03077 seconds
Time After: 0.03127 seconds
Time Before: 0.03149 seconds
Time After: 0.03165 seconds
Time Before: 0.03245 seconds
Time After: 0.03553 seconds
Time Taken: 0.00308 seconds
Time Before: 0.03173 seconds
Time After: 0.03967 seconds
Time Taken: 0.00793 seconds
Time Before: 0.04808 seconds
Time After: 0.04833 seconds
Time Before: 0.05098 seconds
Time After: 0.05221 seconds
Time Before: 0.04732 seconds
Time After: 0.05254 seconds
Time Taken: 0.00522 seconds
Time Before: 0.09212 seconds
Time After: 0.09231 seconds
Time Before: 0.10819 seconds
Time After: 0.10941 seconds
End call of global.php: 0.11166286468506
Time Before: 0.11700 seconds
Time After: 0.11713 seconds
Time Before: 0.11930 seconds
Time After: 0.12073 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=121508', badlocation = 1
Time Before: 0.13801 seconds
Time After: 0.13826 seconds
Page generated in 0.13699889183044 seconds with 9 queries, spending 0.0084640979766846 doing MySQL queries and 0.12853479385376 doing PHP things.
