Time Before: 0.00198 seconds
Time After: 0.00264 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00271 seconds
Time After: 0.00323 seconds
Time Before: 0.00349 seconds
Time After: 0.00360 seconds
Time Before: 0.00431 seconds
Time After: 0.00680 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00365 seconds
Time After: 0.01016 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01240 seconds
Time After: 0.01293 seconds
Time Before: 0.01547 seconds
Time After: 0.01666 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01163 seconds
Time After: 0.01684 seconds
Time Taken: 0.00520 seconds
Memory After: 2,261.703 KB
Time Before: 0.02199 seconds
Time After: 0.02210 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 3.73578 seconds
Time After: 3.73749 seconds
Time Taken: 0.00171 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 3.74191 seconds
Time After: 3.74212 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 3.74546 seconds
Time After: 3.74740 seconds
Time Taken: 0.00195 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121514' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 3.76721 seconds
Time After: 3.77033 seconds
Time Taken: 0.00311 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
