Time Before: 0.01474 seconds
Time After: 0.01975 seconds
Time Taken: 0.00501 seconds
Time Before: 0.01986 seconds
Time After: 0.02031 seconds
Time Before: 0.02057 seconds
Time After: 0.02069 seconds
Time Before: 0.02142 seconds
Time After: 0.02413 seconds
Time Taken: 0.00271 seconds
Time Before: 0.02077 seconds
Time After: 0.02883 seconds
Time Taken: 0.00807 seconds
Time Before: 0.03515 seconds
Time After: 0.03553 seconds
Time Before: 0.03799 seconds
Time After: 0.03924 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03443 seconds
Time After: 0.03946 seconds
Time Taken: 0.00503 seconds
Memory After: 2,261.703 KB
Time Before: 0.05567 seconds
Time After: 0.05582 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07220 seconds
Time After: 0.07345 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.075601100921631
Time Before: 0.08357 seconds
Time After: 0.08374 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08645 seconds
Time After: 0.08801 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=121526', badlocation = 1
Time Before: 0.10859 seconds
Time After: 0.10888 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.10737919807434 seconds with 9 queries, spending 0.0083339214324951 doing MySQL queries and 0.099045276641846 doing PHP things.
