Time Before: 0.00266 seconds
Time After: 0.00433 seconds
Time Taken: 0.00167 seconds
Time Before: 0.00444 seconds
Time After: 0.00501 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00535 seconds
Time After: 0.00551 seconds
Time Before: 0.00654 seconds
Time After: 0.00942 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00560 seconds
Time After: 0.01333 seconds
Time Taken: 0.00773 seconds
Time Before: 0.01540 seconds
Time After: 0.01578 seconds
Time Before: 0.01860 seconds
Time After: 0.02016 seconds
Time Taken: 0.00156 seconds
Time Before: 0.01478 seconds
Time After: 0.02042 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02728 seconds
Time After: 0.02782 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03056 seconds
Time After: 0.03304 seconds
Time Taken: 0.00248 seconds
End call of global.php: 0.034773111343384
Time Before: 0.03645 seconds
Time After: 0.03661 seconds
Time Before: 0.03882 seconds
Time After: 0.04049 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=12158'
Time Before: 0.05658 seconds
Time After: 0.05685 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.055660963058472 seconds with 9 queries, spending 0.010663270950317 doing MySQL queries and 0.044997692108154 doing PHP things.
