Time Before: 0.01122 seconds
Time After: 0.01592 seconds
Time Taken: 0.00470 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01604 seconds
Time After: 0.01669 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01695 seconds
Time After: 0.01706 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01787 seconds
Time After: 0.02018 seconds
Time Taken: 0.00231 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01713 seconds
Time After: 0.02559 seconds
Time Taken: 0.00845 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03131 seconds
Time After: 0.03146 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03378 seconds
Time After: 0.03493 seconds
Time Taken: 0.00114 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03060 seconds
Time After: 0.03511 seconds
Time Taken: 0.00451 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.05489 seconds
Time After: 0.05500 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 1.02900 seconds
Time After: 1.03087 seconds
Time Taken: 0.00187 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 1.0335640907288
Time Before: 1.04568 seconds
Time After: 1.04584 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 1.04933 seconds
Time After: 1.05096 seconds
Time Taken: 0.00163 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772620323, location = '/forums/private.php?do=newpm&explain=1&u=121591', badlocation = 1
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 1.07531 seconds
Time After: 1.07593 seconds
Time Taken: 0.00062 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
Page generated in 1.074077129364 seconds with 9 queries, spending 0.0087735652923584 doing MySQL queries and 1.0653035640717 doing PHP things.
