Time Before: 0.01964 seconds
Time After: 0.02794 seconds
Time Taken: 0.00830 seconds
Time Before: 0.02803 seconds
Time After: 0.02857 seconds
Time Taken: 0.00054 seconds
Time Before: 0.02885 seconds
Time After: 0.02902 seconds
Time Before: 0.02978 seconds
Time After: 0.03240 seconds
Time Taken: 0.00262 seconds
Time Before: 0.02908 seconds
Time After: 0.03671 seconds
Time Taken: 0.00763 seconds
Time Before: 0.04473 seconds
Time After: 0.04518 seconds
Time Before: 0.04776 seconds
Time After: 0.04897 seconds
Time Before: 0.04390 seconds
Time After: 0.04917 seconds
Time Taken: 0.00527 seconds
Time Before: 0.09881 seconds
Time After: 0.09898 seconds
Time Before: 0.11945 seconds
Time After: 0.12077 seconds
Time Taken: 0.00132 seconds
Time Before: 0.13265 seconds
Time After: 0.13286 seconds
Time Before: 0.13569 seconds
Time After: 0.13718 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121610' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.15954 seconds
Time After: 0.15990 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
