Time Before: 0.01909 seconds
Time After: 0.02342 seconds
Time Taken: 0.00433 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02353 seconds
Time After: 0.02423 seconds
Time Taken: 0.00070 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02454 seconds
Time After: 0.02473 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02557 seconds
Time After: 0.02814 seconds
Time Taken: 0.00257 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02479 seconds
Time After: 0.03239 seconds
Time Taken: 0.00760 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04054 seconds
Time After: 0.04091 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04229 seconds
Time After: 0.04352 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03983 seconds
Time After: 0.04376 seconds
Time Taken: 0.00393 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.09124 seconds
Time After: 0.09142 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.45660 seconds
Time After: 0.45812 seconds
Time Taken: 0.00152 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.48241 seconds
Time After: 0.48260 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.48677 seconds
Time After: 0.48835 seconds
Time Taken: 0.00159 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773273105, location = '/forums/private.php?do=newpm&explain=1&u=121622', badlocation = 1 WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.51002 seconds
Time After: 0.51042 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
