Time Before: 0.01751 seconds
Time After: 0.02225 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02232 seconds
Time After: 0.02295 seconds
Time Taken: 0.00062 seconds
Time Before: 0.02321 seconds
Time After: 0.02334 seconds
Time Before: 0.02422 seconds
Time After: 0.02672 seconds
Time Taken: 0.00250 seconds
Time Before: 0.02341 seconds
Time After: 0.03168 seconds
Time Taken: 0.00827 seconds
Time Before: 0.03773 seconds
Time After: 0.03815 seconds
Time Before: 0.04094 seconds
Time After: 0.04219 seconds
Time Before: 0.03698 seconds
Time After: 0.04241 seconds
Time Taken: 0.00543 seconds
Time Before: 0.06964 seconds
Time After: 0.06976 seconds
Time Before: 0.08323 seconds
Time After: 0.08448 seconds
Time Before: 0.09076 seconds
Time After: 0.09092 seconds
Time Before: 0.09319 seconds
Time After: 0.09465 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121655', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11351 seconds
Time After: 0.11379 seconds
