Time Before: 0.01056 seconds
Time After: 0.01297 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01306 seconds
Time After: 0.01354 seconds
Time Before: 0.01386 seconds
Time After: 0.01400 seconds
Time Before: 0.01481 seconds
Time After: 0.01718 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01407 seconds
Time After: 0.02146 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02622 seconds
Time After: 0.02644 seconds
Time Before: 0.02900 seconds
Time After: 0.03021 seconds
Time Before: 0.02541 seconds
Time After: 0.03042 seconds
Time Taken: 0.00501 seconds
Time Before: 0.05125 seconds
Time After: 0.05141 seconds
Time Before: 0.05843 seconds
Time After: 0.05973 seconds
End call of global.php: 0.062147855758667
Time Before: 0.06622 seconds
Time After: 0.06648 seconds
Time Before: 0.06922 seconds
Time After: 0.07071 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=121694'
Time Before: 0.08619 seconds
Time After: 0.08665 seconds
Page generated in 0.085281848907471 seconds with 9 queries, spending 0.0080668926239014 doing MySQL queries and 0.077214956283569 doing PHP things.
