Time Before: 0.01104 seconds
Time After: 0.01559 seconds
Time Taken: 0.00455 seconds
Time Before: 0.01570 seconds
Time After: 0.01714 seconds
Time Before: 0.01740 seconds
Time After: 0.01754 seconds
Time Before: 0.01825 seconds
Time After: 0.02070 seconds
Time Taken: 0.00245 seconds
Time Before: 0.01760 seconds
Time After: 0.02594 seconds
Time Taken: 0.00835 seconds
Time Before: 0.03426 seconds
Time After: 0.03467 seconds
Time Before: 0.03673 seconds
Time After: 0.03799 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03354 seconds
Time After: 0.03822 seconds
Time Taken: 0.00468 seconds
Memory After: 2,261.703 KB
Time Before: 0.05677 seconds
Time After: 0.05693 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06913 seconds
Time After: 0.07043 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.072341918945312
Time Before: 0.07638 seconds
Time After: 0.07656 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07895 seconds
Time After: 0.08039 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=121695'
Time Before: 0.09635 seconds
Time After: 0.09676 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.095364809036255 seconds with 9 queries, spending 0.0091927051544189 doing MySQL queries and 0.086172103881836 doing PHP things.
