Time Before: 0.00142 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00227 seconds
Time Before: 0.00245 seconds
Time After: 0.00257 seconds
Time Before: 0.00323 seconds
Time After: 0.00535 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00262 seconds
Time After: 0.00879 seconds
Time Taken: 0.00618 seconds
Time Before: 0.01054 seconds
Time After: 0.01088 seconds
Time Before: 0.01321 seconds
Time After: 0.01438 seconds
Time Taken: 0.00117 seconds
Time Before: 0.00995 seconds
Time After: 0.01456 seconds
Time Taken: 0.00462 seconds
Time Before: 0.02159 seconds
Time After: 0.02198 seconds
Time Before: 0.02433 seconds
Time After: 0.02568 seconds
Time Taken: 0.00135 seconds
Time Before: 0.02886 seconds
Time After: 0.02902 seconds
Time Before: 0.03127 seconds
Time After: 0.03268 seconds
UPDATE session SET lastactivity = 1783264652, location = '/forums/private.php?do=newpm&explain=1&u=121720', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04738 seconds
Time After: 0.04769 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
