Time Before: 0.01800 seconds
Time After: 0.02439 seconds
Time Taken: 0.00639 seconds
Time Before: 0.02451 seconds
Time After: 0.02492 seconds
Time Before: 0.02515 seconds
Time After: 0.02527 seconds
Time Before: 0.02610 seconds
Time After: 0.02811 seconds
Time Taken: 0.00201 seconds
Time Before: 0.02534 seconds
Time After: 0.03342 seconds
Time Taken: 0.00808 seconds
Time Before: 0.04320 seconds
Time After: 0.04361 seconds
Time Before: 0.04551 seconds
Time After: 0.04694 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04235 seconds
Time After: 0.04717 seconds
Time Taken: 0.00482 seconds
Memory After: 2,261.820 KB
Time Before: 0.08079 seconds
Time After: 0.08094 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10098 seconds
Time After: 0.10222 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.11314 seconds
Time After: 0.11329 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11642 seconds
Time After: 0.11798 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789107401, location = '/forums/private.php?do=newpm&explain=1&u=121771' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.13750 seconds
Time After: 0.13775 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
