Time Before: 0.00306 seconds
Time After: 0.00397 seconds
Time Taken: 0.00091 seconds
Time Before: 0.00408 seconds
Time After: 0.00460 seconds
Time Before: 0.00484 seconds
Time After: 0.00495 seconds
Time Before: 0.00562 seconds
Time After: 0.00852 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00500 seconds
Time After: 0.01192 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01497 seconds
Time After: 0.01547 seconds
Time Before: 0.01816 seconds
Time After: 0.01937 seconds
Time Before: 0.01375 seconds
Time After: 0.01959 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02462 seconds
Time After: 0.02474 seconds
Time Before: 0.02652 seconds
Time After: 0.02774 seconds
Time Before: 0.03048 seconds
Time After: 0.03061 seconds
Time Before: 0.03254 seconds
Time After: 0.03397 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121775' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04831 seconds
Time After: 0.04860 seconds
