Time Before: 0.01378 seconds
Time After: 0.01815 seconds
Time Taken: 0.00438 seconds
Time Before: 0.01825 seconds
Time After: 0.01923 seconds
Time Taken: 0.00098 seconds
Time Before: 0.02493 seconds
Time After: 0.02510 seconds
Time Before: 0.02595 seconds
Time After: 0.02905 seconds
Time Taken: 0.00310 seconds
Time Before: 0.02518 seconds
Time After: 0.03401 seconds
Time Taken: 0.00883 seconds
Time Before: 0.04006 seconds
Time After: 0.04046 seconds
Time Before: 0.04294 seconds
Time After: 0.04423 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03938 seconds
Time After: 0.04448 seconds
Time Taken: 0.00509 seconds
Memory After: 2,261.703 KB
Time Before: 0.06462 seconds
Time After: 0.06490 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07532 seconds
Time After: 0.07662 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.08404 seconds
Time After: 0.08420 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08711 seconds
Time After: 0.08870 seconds
Time Taken: 0.00160 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121829', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.10768 seconds
Time After: 0.10817 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
