Time Before: 0.00741 seconds
Time After: 0.01007 seconds
Time Taken: 0.00265 seconds
Time Before: 0.01017 seconds
Time After: 0.01066 seconds
Time Before: 0.01092 seconds
Time After: 0.01105 seconds
Time Before: 0.01184 seconds
Time After: 0.01397 seconds
Time Taken: 0.00213 seconds
Time Before: 0.01112 seconds
Time After: 0.01803 seconds
Time Taken: 0.00691 seconds
Time Before: 0.02253 seconds
Time After: 0.02294 seconds
Time Before: 0.02533 seconds
Time After: 0.02655 seconds
Time Before: 0.02182 seconds
Time After: 0.02682 seconds
Time Taken: 0.00500 seconds
Time Before: 0.04385 seconds
Time After: 0.04402 seconds
Time Before: 0.05166 seconds
Time After: 0.05294 seconds
End call of global.php: 0.055351972579956
Time Before: 0.05821 seconds
Time After: 0.05837 seconds
Time Before: 0.06130 seconds
Time After: 0.06275 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=121837'
Time Before: 0.08154 seconds
Time After: 0.08186 seconds
Page generated in 0.080472946166992 seconds with 9 queries, spending 0.0077309608459473 doing MySQL queries and 0.072741985321045 doing PHP things.
