Time Before: 0.00151 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00265 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00289 seconds
Time After: 0.00303 seconds
Time Before: 0.00365 seconds
Time After: 0.00610 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00308 seconds
Time After: 0.00957 seconds
Time Taken: 0.00650 seconds
Time Before: 0.01143 seconds
Time After: 0.01184 seconds
Time Before: 0.01448 seconds
Time After: 0.01563 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01079 seconds
Time After: 0.01581 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02091 seconds
Time After: 0.02104 seconds
Time Before: 0.02274 seconds
Time After: 0.02396 seconds
Time Before: 0.02692 seconds
Time After: 0.02705 seconds
Time Before: 0.02906 seconds
Time After: 0.03049 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121859', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04396 seconds
Time After: 0.04441 seconds
