Time Before: 0.03030 seconds
Time After: 0.03681 seconds
Time Taken: 0.00650 seconds
Time Before: 0.03690 seconds
Time After: 0.03738 seconds
Time Before: 0.03758 seconds
Time After: 0.03774 seconds
Time Before: 0.03845 seconds
Time After: 0.04033 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03779 seconds
Time After: 0.04566 seconds
Time Taken: 0.00787 seconds
Time Before: 0.05801 seconds
Time After: 0.05840 seconds
Time Before: 0.06117 seconds
Time After: 0.06234 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05722 seconds
Time After: 0.06254 seconds
Time Taken: 0.00532 seconds
Time Before: 0.10542 seconds
Time After: 0.10556 seconds
Time Before: 0.12013 seconds
Time After: 0.12136 seconds
Time Before: 0.13186 seconds
Time After: 0.13202 seconds
Time Before: 0.13525 seconds
Time After: 0.13673 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=121954' WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.15579 seconds
Time After: 0.15609 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
