Time Before: 0.01590 seconds
Time After: 0.02003 seconds
Time Taken: 0.00413 seconds
Time Before: 0.02012 seconds
Time After: 0.02060 seconds
Time Before: 0.02088 seconds
Time After: 0.02103 seconds
Time Before: 0.02192 seconds
Time After: 0.02713 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02111 seconds
Time After: 0.03272 seconds
Time Taken: 0.01162 seconds
Time Before: 0.03916 seconds
Time After: 0.03959 seconds
Time Before: 0.04228 seconds
Time After: 0.04352 seconds
Time Before: 0.03845 seconds
Time After: 0.04377 seconds
Time Taken: 0.00532 seconds
Time Before: 0.07182 seconds
Time After: 0.07203 seconds
Time Before: 0.08526 seconds
Time After: 0.08662 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.088357210159302
Time Before: 0.09377 seconds
Time After: 0.09396 seconds
Time Before: 0.09614 seconds
Time After: 0.09757 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=122060', badlocation = 1
Time Before: 0.11150 seconds
Time After: 0.11180 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.11059522628784 seconds with 9 queries, spending 0.010976076126099 doing MySQL queries and 0.099619150161743 doing PHP things.
