Time Before: 0.00179 seconds
Time After: 0.00232 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00240 seconds
Time After: 0.00293 seconds
Time Before: 0.00322 seconds
Time After: 0.00340 seconds
Time Before: 0.00447 seconds
Time After: 0.00755 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00346 seconds
Time After: 0.01125 seconds
Time Taken: 0.00778 seconds
Time Before: 0.01377 seconds
Time After: 0.01419 seconds
Time Before: 0.01728 seconds
Time After: 0.01937 seconds
Time Taken: 0.00209 seconds
Time Before: 0.01308 seconds
Time After: 0.01974 seconds
Time Taken: 0.00666 seconds
Time Before: 0.02694 seconds
Time After: 0.02713 seconds
Time Before: 0.02971 seconds
Time After: 0.03095 seconds
Time Before: 0.03473 seconds
Time After: 0.03491 seconds
Time Before: 0.03848 seconds
Time After: 0.03996 seconds
UPDATE session SET lastactivity = 1788887738, location = '/forums/private.php?do=newpm&explain=1&u=12214', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05992 seconds
Time After: 0.06024 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
