Time Before: 0.02855 seconds
Time After: 0.03769 seconds
Time Taken: 0.00914 seconds
Time Before: 0.03782 seconds
Time After: 0.03822 seconds
Time Before: 0.03847 seconds
Time After: 0.03861 seconds
Time Before: 0.03946 seconds
Time After: 0.04200 seconds
Time Taken: 0.00254 seconds
Time Before: 0.03868 seconds
Time After: 0.04580 seconds
Time Taken: 0.00712 seconds
Time Before: 0.05521 seconds
Time After: 0.05561 seconds
Time Before: 0.05892 seconds
Time After: 0.06143 seconds
Time Taken: 0.00251 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05449 seconds
Time After: 0.06165 seconds
Time Taken: 0.00716 seconds
Memory After: 2,261.820 KB
Time Before: 0.10816 seconds
Time After: 0.10934 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.13091 seconds
Time After: 0.13216 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.14411 seconds
Time After: 0.14433 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.14792 seconds
Time After: 0.14936 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789034442, location = '/forums/private.php?do=newpm&explain=1&u=122163', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.17052 seconds
Time After: 0.17084 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
