Time Before: 0.00184 seconds
Time After: 0.00256 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00269 seconds
Time After: 0.00313 seconds
Time Before: 0.00331 seconds
Time After: 0.00346 seconds
Time Before: 0.00417 seconds
Time After: 0.00761 seconds
Time Taken: 0.00344 seconds
Time Before: 0.00350 seconds
Time After: 0.01112 seconds
Time Taken: 0.00761 seconds
Time Before: 0.01292 seconds
Time After: 0.01336 seconds
Time Before: 0.01607 seconds
Time After: 0.01772 seconds
Time Taken: 0.00165 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01227 seconds
Time After: 0.01792 seconds
Time Taken: 0.00565 seconds
Memory After: 2,261.703 KB
Time Before: 0.02302 seconds
Time After: 0.02315 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02537 seconds
Time After: 0.02726 seconds
Time Taken: 0.00189 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.028999090194702
Time Before: 0.03070 seconds
Time After: 0.03085 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03317 seconds
Time After: 0.03461 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=122194'
Time Before: 0.04813 seconds
Time After: 0.04870 seconds
Time Taken: 0.00057 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.047242164611816 seconds with 9 queries, spending 0.010281085968018 doing MySQL queries and 0.036961078643799 doing PHP things.
