Time Before: 0.02083 seconds
Time After: 0.02747 seconds
Time Taken: 0.00664 seconds
Time Before: 0.02758 seconds
Time After: 0.02804 seconds
Time Before: 0.02834 seconds
Time After: 0.02851 seconds
Time Before: 0.02927 seconds
Time After: 0.03162 seconds
Time Taken: 0.00234 seconds
Time Before: 0.02858 seconds
Time After: 0.03520 seconds
Time Taken: 0.00662 seconds
Time Before: 0.04349 seconds
Time After: 0.04388 seconds
Time Before: 0.04625 seconds
Time After: 0.04747 seconds
Time Before: 0.04285 seconds
Time After: 0.04765 seconds
Time Taken: 0.00481 seconds
Time Before: 0.08611 seconds
Time After: 0.08628 seconds
Time Before: 0.17833 seconds
Time After: 0.17962 seconds
Time Before: 0.19204 seconds
Time After: 0.19222 seconds
Time Before: 0.19457 seconds
Time After: 0.19604 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=12226', badlocation = 1 WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.21874 seconds
Time After: 0.21902 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
