Time Before: 0.01780 seconds
Time After: 0.02352 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02361 seconds
Time After: 0.02403 seconds
Time Before: 0.02427 seconds
Time After: 0.02439 seconds
Time Before: 0.02520 seconds
Time After: 0.02738 seconds
Time Taken: 0.00217 seconds
Time Before: 0.02444 seconds
Time After: 0.03139 seconds
Time Taken: 0.00695 seconds
Time Before: 0.03771 seconds
Time After: 0.03811 seconds
Time Before: 0.04073 seconds
Time After: 0.04197 seconds
Time Before: 0.03690 seconds
Time After: 0.04228 seconds
Time Taken: 0.00538 seconds
Time Before: 0.06225 seconds
Time After: 0.06239 seconds
Time Before: 0.07424 seconds
Time After: 0.07550 seconds
Time Before: 0.08340 seconds
Time After: 0.08355 seconds
Time Before: 0.08633 seconds
Time After: 0.08781 seconds
UPDATE session SET lastactivity = 1783148371, location = '/forums/private.php?do=newpm&explain=1&u=122265' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.10546 seconds
Time After: 0.10774 seconds
Time Taken: 0.00228 seconds
