Time Before: 0.01728 seconds
Time After: 0.02262 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02271 seconds
Time After: 0.02314 seconds
Time Before: 0.02348 seconds
Time After: 0.02362 seconds
Time Before: 0.02448 seconds
Time After: 0.02663 seconds
Time Taken: 0.00214 seconds
Time Before: 0.02368 seconds
Time After: 0.03064 seconds
Time Taken: 0.00696 seconds
Time Before: 0.03748 seconds
Time After: 0.03800 seconds
Time Taken: 0.00053 seconds
Time Before: 0.04102 seconds
Time After: 0.04308 seconds
Time Taken: 0.00206 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03666 seconds
Time After: 0.04335 seconds
Time Taken: 0.00669 seconds
Memory After: 2,261.703 KB
Time Before: 0.07956 seconds
Time After: 0.07983 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10917 seconds
Time After: 0.11097 seconds
Time Taken: 0.00179 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12102 seconds
Time After: 0.12166 seconds
Time Taken: 0.00064 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12491 seconds
Time After: 0.12705 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122308', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14834 seconds
Time After: 0.14865 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
