Time Before: 0.00149 seconds
Time After: 0.00200 seconds
Time Before: 0.00207 seconds
Time After: 0.00257 seconds
Time Before: 0.00283 seconds
Time After: 0.00299 seconds
Time Before: 0.00365 seconds
Time After: 0.00604 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00304 seconds
Time After: 0.00943 seconds
Time Taken: 0.00640 seconds
Time Before: 0.01125 seconds
Time After: 0.01155 seconds
Time Before: 0.01427 seconds
Time After: 0.01547 seconds
Time Before: 0.01061 seconds
Time After: 0.01565 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02187 seconds
Time After: 0.02209 seconds
Time Before: 0.02428 seconds
Time After: 0.02556 seconds
Time Before: 0.02851 seconds
Time After: 0.02871 seconds
Time Before: 0.03061 seconds
Time After: 0.03220 seconds
Time Taken: 0.00159 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122310', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.05020 seconds
Time After: 0.05051 seconds
