Time Before: 0.01965 seconds
Time After: 0.02656 seconds
Time Taken: 0.00691 seconds
Time Before: 0.02667 seconds
Time After: 0.02709 seconds
Time Before: 0.02734 seconds
Time After: 0.02748 seconds
Time Before: 0.02837 seconds
Time After: 0.03098 seconds
Time Taken: 0.00261 seconds
Time Before: 0.02756 seconds
Time After: 0.03513 seconds
Time Taken: 0.00757 seconds
Time Before: 0.04338 seconds
Time After: 0.04380 seconds
Time Before: 0.04562 seconds
Time After: 0.04802 seconds
Time Taken: 0.00240 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04256 seconds
Time After: 0.04828 seconds
Time Taken: 0.00572 seconds
Memory After: 2,261.703 KB
Time Before: 0.08545 seconds
Time After: 0.08559 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10077 seconds
Time After: 0.10201 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.10414981842041
Time Before: 0.11009 seconds
Time After: 0.11025 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.11268 seconds
Time After: 0.11416 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=122346'
Time Before: 0.13226 seconds
Time After: 0.13264 seconds
Memory Before: 4,288.000 KB
Memory After: 4,288.242 KB
Page generated in 0.13101291656494 seconds with 9 queries, spending 0.0093710422515869 doing MySQL queries and 0.12164187431335 doing PHP things.
