Time Before: 0.00136 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00235 seconds
Time Before: 0.00260 seconds
Time After: 0.00274 seconds
Time Before: 0.00356 seconds
Time After: 0.00566 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00282 seconds
Time After: 0.00984 seconds
Time Taken: 0.00703 seconds
Time Before: 0.01165 seconds
Time After: 0.01208 seconds
Time Before: 0.01472 seconds
Time After: 0.01595 seconds
Time Before: 0.01109 seconds
Time After: 0.01620 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02287 seconds
Time After: 0.02304 seconds
Time Before: 0.02674 seconds
Time After: 0.02799 seconds
End call of global.php: 0.029674053192139
Time Before: 0.03083 seconds
Time After: 0.03099 seconds
Time Before: 0.03403 seconds
Time After: 0.03587 seconds
Time Taken: 0.00184 seconds
SET lastactivity = 1789145492, location = '/forums/private.php?do=newpm&explain=1&u=122363', badlocation = 1
Time Before: 0.05000 seconds
Time After: 0.05037 seconds
Page generated in 0.049067974090576 seconds with 9 queries, spending 0.0081479549407959 doing MySQL queries and 0.04092001914978 doing PHP things.
