Time Before: 0.01101 seconds
Time After: 0.01390 seconds
Time Taken: 0.00289 seconds
Time Before: 0.01402 seconds
Time After: 0.01450 seconds
Time Before: 0.01478 seconds
Time After: 0.01499 seconds
Time Before: 0.01583 seconds
Time After: 0.01832 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01507 seconds
Time After: 0.02275 seconds
Time Taken: 0.00768 seconds
Time Before: 0.02697 seconds
Time After: 0.02735 seconds
Time Before: 0.02994 seconds
Time After: 0.03111 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02630 seconds
Time After: 0.03130 seconds
Time Taken: 0.00500 seconds
Time Before: 0.05310 seconds
Time After: 0.05323 seconds
Time Before: 0.05873 seconds
Time After: 0.05998 seconds
Time Before: 0.06640 seconds
Time After: 0.06657 seconds
Time Before: 0.06923 seconds
Time After: 0.07070 seconds
UPDATE session SET lastactivity = 1785474794, location = '/forums/private.php?do=newpm&explain=1&u=122393' WHERE sessionhash = 'f787d15acff2abe23491441932164758'
Time Before: 0.09021 seconds
Time After: 0.09048 seconds
