Time Before: 0.00253 seconds
Time After: 0.00308 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00316 seconds
Time After: 0.00389 seconds
Time Taken: 0.00073 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00424 seconds
Time After: 0.00457 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00535 seconds
Time After: 0.00864 seconds
Time Taken: 0.00330 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00464 seconds
Time After: 0.01207 seconds
Time Taken: 0.00743 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01409 seconds
Time After: 0.01461 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01690 seconds
Time After: 0.01820 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01347 seconds
Time After: 0.01839 seconds
Time Taken: 0.00492 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02458 seconds
Time After: 0.02479 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03255 seconds
Time After: 0.03390 seconds
Time Taken: 0.00135 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04168 seconds
Time After: 0.04190 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04406 seconds
Time After: 0.04558 seconds
Time Taken: 0.00152 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122396' WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.05916 seconds
Time After: 0.05952 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
