Time Before: 0.00140 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00235 seconds
Time Before: 0.00255 seconds
Time After: 0.00269 seconds
Time Before: 0.00342 seconds
Time After: 0.00642 seconds
Time Taken: 0.00300 seconds
Time Before: 0.00274 seconds
Time After: 0.01177 seconds
Time Taken: 0.00903 seconds
Time Before: 0.01404 seconds
Time After: 0.01450 seconds
Time Before: 0.01777 seconds
Time After: 0.01896 seconds
Time Before: 0.01326 seconds
Time After: 0.01922 seconds
Time Taken: 0.00596 seconds
Time Before: 0.02543 seconds
Time After: 0.02557 seconds
Time Before: 0.02794 seconds
Time After: 0.02929 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.032000064849854
Time Before: 0.03334 seconds
Time After: 0.03352 seconds
Time Before: 0.03673 seconds
Time After: 0.03820 seconds
SET lastactivity = 1785425808, location = '/forums/private.php?do=newpm&explain=1&u=122403'
Time Before: 0.05305 seconds
Time After: 0.05333 seconds
Page generated in 0.052119016647339 seconds with 9 queries, spending 0.0086066722869873 doing MySQL queries and 0.043512344360352 doing PHP things.
