Time Before: 0.01484 seconds
Time After: 0.02121 seconds
Time Taken: 0.00637 seconds
Time Before: 0.02132 seconds
Time After: 0.02191 seconds
Time Taken: 0.00059 seconds
Time Before: 0.02219 seconds
Time After: 0.02237 seconds
Time Before: 0.02315 seconds
Time After: 0.02545 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02245 seconds
Time After: 0.02988 seconds
Time Taken: 0.00743 seconds
Time Before: 0.03590 seconds
Time After: 0.03632 seconds
Time Before: 0.03885 seconds
Time After: 0.04004 seconds
Time Before: 0.03515 seconds
Time After: 0.04030 seconds
Time Taken: 0.00515 seconds
Time Before: 0.06537 seconds
Time After: 0.06561 seconds
Time Before: 0.07804 seconds
Time After: 0.07936 seconds
Time Taken: 0.00131 seconds
Time Before: 0.09318 seconds
Time After: 0.09343 seconds
Time Before: 0.09726 seconds
Time After: 0.09870 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122416', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.11929 seconds
Time After: 0.11958 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
