Time Before: 0.01963 seconds
Time After: 0.02380 seconds
Time Taken: 0.00417 seconds
Time Before: 0.02391 seconds
Time After: 0.02433 seconds
Time Before: 0.02455 seconds
Time After: 0.02467 seconds
Time Before: 0.02549 seconds
Time After: 0.02773 seconds
Time Taken: 0.00224 seconds
Time Before: 0.02474 seconds
Time After: 0.03238 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03813 seconds
Time After: 0.03854 seconds
Time Before: 0.04088 seconds
Time After: 0.04211 seconds
Time Before: 0.03741 seconds
Time After: 0.04234 seconds
Time Taken: 0.00492 seconds
Time Before: 0.07631 seconds
Time After: 0.07649 seconds
Time Before: 0.08877 seconds
Time After: 0.09002 seconds
Time Before: 0.10002 seconds
Time After: 0.10021 seconds
Time Before: 0.10313 seconds
Time After: 0.10463 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1776659961, location = '/forums/private.php?do=newpm&explain=1&u=122456' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.12252 seconds
Time After: 0.12290 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
