Time Before: 0.00199 seconds
Time After: 0.00256 seconds
Time Taken: 0.00057 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.00266 seconds
Time After: 0.00314 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.00338 seconds
Time After: 0.00351 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.00437 seconds
Time After: 0.00698 seconds
Time Taken: 0.00260 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.00359 seconds
Time After: 0.01058 seconds
Time Taken: 0.00699 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.01249 seconds
Time After: 0.01288 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.01554 seconds
Time After: 0.01675 seconds
Memory Before: 2,148.281 KB
Memory After: 2,148.141 KB
Time Before: 0.01176 seconds
Time After: 0.01699 seconds
Time Taken: 0.00524 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.164 KB
Time Before: 0.02248 seconds
Time After: 0.02262 seconds
Memory Before: 2,814.719 KB
Memory After: 2,815.234 KB
Time Before: 0.02555 seconds
Time After: 0.02720 seconds
Time Taken: 0.00165 seconds
Memory Before: 2,903.047 KB
Memory After: 2,903.641 KB
End call of global.php: 0.029687166213989
Time Before: 0.03123 seconds
Time After: 0.03136 seconds
Memory Before: 3,539.773 KB
Memory After: 3,540.203 KB
Time Before: 0.03340 seconds
Time After: 0.03486 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=122469'
Time Before: 0.04997 seconds
Time After: 0.05038 seconds
Memory Before: 4,294.930 KB
Memory After: 4,295.172 KB
Page generated in 0.049082040786743 seconds with 9 queries, spending 0.008608341217041 doing MySQL queries and 0.040473699569702 doing PHP things.
