Time Before: 0.02547 seconds
Time After: 0.03082 seconds
Time Taken: 0.00536 seconds
Time Before: 0.03092 seconds
Time After: 0.03137 seconds
Time Before: 0.03162 seconds
Time After: 0.03177 seconds
Time Before: 0.03270 seconds
Time After: 0.03546 seconds
Time Taken: 0.00277 seconds
Time Before: 0.03185 seconds
Time After: 0.04018 seconds
Time Taken: 0.00833 seconds
Time Before: 0.04900 seconds
Time After: 0.04944 seconds
Time Before: 0.05216 seconds
Time After: 0.05336 seconds
Time Before: 0.04822 seconds
Time After: 0.05355 seconds
Time Taken: 0.00533 seconds
Time Before: 0.09599 seconds
Time After: 0.09615 seconds
Time Before: 0.11417 seconds
Time After: 0.11542 seconds
End call of global.php: 0.11760592460632
Time Before: 0.12193 seconds
Time After: 0.12223 seconds
Time Before: 0.12493 seconds
Time After: 0.12685 seconds
Time Taken: 0.00191 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=122473'
Time Before: 0.15105 seconds
Time After: 0.15134 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.14990091323853 seconds with 9 queries, spending 0.0089242458343506 doing MySQL queries and 0.14097666740417 doing PHP things.
