Time Before: 0.02749 seconds
Time After: 0.03647 seconds
Time Taken: 0.00898 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.03656 seconds
Time After: 0.03702 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.03725 seconds
Time After: 0.03742 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.03821 seconds
Time After: 0.04101 seconds
Time Taken: 0.00280 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.03747 seconds
Time After: 0.04515 seconds
Time Taken: 0.00767 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.05524 seconds
Time After: 0.05564 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.05722 seconds
Time After: 0.05851 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.05445 seconds
Time After: 0.05874 seconds
Time Taken: 0.00429 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.10718 seconds
Time After: 0.10740 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.12290 seconds
Time After: 0.12417 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.13538 seconds
Time After: 0.13555 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.13815 seconds
Time After: 0.13978 seconds
Time Taken: 0.00163 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122525' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.15424 seconds
Time After: 0.15446 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
