Time Before: 0.01328 seconds
Time After: 0.01807 seconds
Time Taken: 0.00479 seconds
Time Before: 0.01818 seconds
Time After: 0.01861 seconds
Time Before: 0.01884 seconds
Time After: 0.01900 seconds
Time Before: 0.01983 seconds
Time After: 0.02222 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01908 seconds
Time After: 0.02720 seconds
Time Taken: 0.00812 seconds
Time Before: 0.03269 seconds
Time After: 0.03312 seconds
Time Before: 0.03576 seconds
Time After: 0.03706 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03201 seconds
Time After: 0.03725 seconds
Time Taken: 0.00524 seconds
Memory After: 2,261.703 KB
Time Before: 0.06255 seconds
Time After: 0.06272 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07745 seconds
Time After: 0.07871 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.08626 seconds
Time After: 0.08697 seconds
Time Taken: 0.00071 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08963 seconds
Time After: 0.09105 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=122533', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10990 seconds
Time After: 0.11017 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.508 KB
