Time Before: 0.00187 seconds
Time After: 0.00370 seconds
Time Taken: 0.00183 seconds
Time Before: 0.00380 seconds
Time After: 0.00435 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00460 seconds
Time After: 0.00470 seconds
Time Before: 0.00537 seconds
Time After: 0.00786 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00476 seconds
Time After: 0.01121 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01300 seconds
Time After: 0.01336 seconds
Time Before: 0.01575 seconds
Time After: 0.01707 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01241 seconds
Time After: 0.01724 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02237 seconds
Time After: 0.02262 seconds
Time Before: 0.02481 seconds
Time After: 0.02613 seconds
End call of global.php: 0.027765989303589
Time Before: 0.02927 seconds
Time After: 0.02946 seconds
Time Before: 0.03156 seconds
Time After: 0.03305 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=122580'
Time Before: 0.04585 seconds
Time After: 0.04620 seconds
Page generated in 0.04455304145813 seconds with 9 queries, spending 0.0084447860717773 doing MySQL queries and 0.036108255386353 doing PHP things.
