Time Before: 0.00552 seconds
Time After: 0.00866 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00877 seconds
Time After: 0.00919 seconds
Time Before: 0.00939 seconds
Time After: 0.00954 seconds
Time Before: 0.01038 seconds
Time After: 0.01318 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00960 seconds
Time After: 0.01725 seconds
Time Taken: 0.00765 seconds
Time Before: 0.02083 seconds
Time After: 0.02105 seconds
Time Before: 0.02261 seconds
Time After: 0.02407 seconds
Time Before: 0.02017 seconds
Time After: 0.02428 seconds
Time Taken: 0.00411 seconds
Time Before: 0.03565 seconds
Time After: 0.03580 seconds
Time Before: 0.04149 seconds
Time After: 0.04279 seconds
End call of global.php: 0.04531717300415
Time Before: 0.04805 seconds
Time After: 0.04822 seconds
Time Before: 0.05136 seconds
Time After: 0.05299 seconds
Time Taken: 0.00163 seconds
SET lastactivity = 1782975851, location = '/forums/private.php?do=newpm&explain=1&u=122631', badlocation = 1
Time Before: 0.07077 seconds
Time After: 0.07106 seconds
Page generated in 0.069647073745728 seconds with 9 queries, spending 0.0085816383361816 doing MySQL queries and 0.061065435409546 doing PHP things.
