Time Before: 0.02073 seconds
Time After: 0.02902 seconds
Time Taken: 0.00829 seconds
Time Before: 0.02914 seconds
Time After: 0.02961 seconds
Time Before: 0.02983 seconds
Time After: 0.02996 seconds
Time Before: 0.03062 seconds
Time After: 0.03319 seconds
Time Taken: 0.00257 seconds
Time Before: 0.03001 seconds
Time After: 0.03683 seconds
Time Taken: 0.00683 seconds
Time Before: 0.04621 seconds
Time After: 0.04656 seconds
Time Before: 0.04965 seconds
Time After: 0.05106 seconds
Time Before: 0.04499 seconds
Time After: 0.05127 seconds
Time Taken: 0.00628 seconds
Time Before: 0.09045 seconds
Time After: 0.09058 seconds
Time Before: 0.11296 seconds
Time After: 0.11417 seconds
End call of global.php: 0.11633086204529
Time Before: 0.12591 seconds
Time After: 0.12609 seconds
Time Before: 0.12851 seconds
Time After: 0.13004 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=122639', badlocation = 1
Time Before: 0.14983 seconds
Time After: 0.15009 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.14857387542725 seconds with 9 queries, spending 0.0082406997680664 doing MySQL queries and 0.14033317565918 doing PHP things.
